Does anyone have a diagram of the grounding wires for 2000 chevy Impala?
sky
Car wont start. i just need to know where the ground wires are so i can check to see if they are all in place.
Places like parts source may have a free print out of such info or ask a dealership customer service rep, otherwise trace the negative battery post wires they will lead you to the main grounds such as the engine block ground, also check the starter area over it may have it's own ground strap, take a good look at the frame, chassis and you'll find other grounds.Remember ever electrical/electronic device has to use a ground and comp systems may ground some sensors or devices too.
Hope that helps and best of luck.By the way in the past parts source has helped me quite a bit with diagrams/schematics and also some of the more friendly/customer service oriented dealerships have been helpful too.
