Dealer suggested to replace both control arms... but I dont believe him
So here is the story:
I noticed that my steering a bit of centered... I went to the dealer and asked to do alignment, they call me back and made me happy saying you need to replace both from control arms in order to proceed with alignment and it will cost you 1000$+TAX (CAD) and the reason is right one has loose ball joint, left has bushing torn ....
Wow.... what a surprise, I've canceled all that.... when I got my car back I rise my car and when wheel was off the ground grabbed it and tried to rock it left-to-right... then top-to-bottom.... when I did left to right rocking I noticed some dull "cling" noise I suspect this was the a tie rod and steering thing... because when car on parking and I spinning st wheel left-right quickly I have similar noise.....
Then I removed left wheel and examined all what I can see around. Tried to rock tie rods, control arm (impossible to move at all, it is dead on)... what I notice though I can move by hands that big bar which comes from left to right sides... (stabilizer ?) I suspect this thing rattles when I go over potholes...
Didn't see any torn bushings on control arm, didn't see torn ball joint rubber... but could check ball joint movements because it constantly loaded by spring.
May be if I have time I will check left side as well.... to see what is going on with bushings.
Any advise on that? What other test I can do to localize the problem if it exists?
PS. I hope I've explained the story well enough with my so-so English grammar.
