Chimes/beeps when starting or shutting off engine
thicks70
Good day all. I recently purchased a 2006 Z71 Suburban and love it. However, the other night when leaving work, I noticed a 'chime' sound coming from the dash when I started the truck, and heard the same sound when I shut it off. has anyone experienced this and if so, what has done to correct it or what is the issue? Thanks In Advance.
Was your drivers door open?
No, this is NOT the key in the ignition chime. This occurs when I try to start the truck and after I shut it off. Now it won't start at all. I turn the key and get nothing.
does the radio work, heater fan,anything? do you have a voltmeter to test the battery? did you check all fuses?
Assuming your burb is 4 x 4
LS or LT trim level?
6.0 L or 8.0 L
I am trying to find the chime/beep for your vehicle but I have to limit my search more closely to you exact vehicle.
