This question is pretty much for ANYONE that owns a chevy malibu. I'm sure this has happened to you if the car is over 50,000 miles, whenever you attempt to start the car every so often the theft light will go on and blink and it won't turn over meaning you have to wait 10 minutes to start the car with the key turned to on.
Does ANYONE have a solution to this problem other than cutting the yellow wire or getting the ignition replaced??? I'm getting fed up with this problem and it's starting to happen almost once a week! Any suggestions are appreciated.
