Chevy Malibu has no power ?
bleached_baboon
My automatic Malibu has started acting very odd this week. It accelerated fine off the line but then power just drops off to nothing. Once I get the RPMs up a bit (to around 2800 or so) acceleration kicks in and everything is fine until it is time to shift. The car won't shift up unless I let my foot off the pedal. Then when it does, I am back to the same spot I had with the gear prior. No power until the RPMs are up around 2800 again.
At the suggestion of a mechanic, I replaced the Mass Air Flow Sensor as he says I am getting restricted air flow. The car sat idle for a long time and had a number of codes come up from the check engine light:
P0300
P0125
P0131
P0400
P0404
P1189
U1040
The 0400 and 0404 were from when my wife forgot to put the gas cap back on I am pretty sure.
Anyone have any ideas. I know it is a lot to ask but times are tough and mechanics in the bay area are really expensive.
Thanks.
places like parts america or autozone can tell you what the codes mean for free.
Ok, a long one to be sure, but here goes, and you figure it out-
300- random misfire
125-not enough cooling, closed loop
137-02 sensor, low volts, bank one, sensor one
400-egr flow malfunction
404-egr flow, ckt, range/perf
1189,- engine oil pressure switch circuit
1040-Manf Centrl fuel /air metering, aux emission controls
These are the book readings of the trouble codes plus the last two are the manufacturers codes.
sounds like you may have a lot of miles on this car, with little or no maintenance, or just a bummer with these many problems.
Good luck with the diagnostics.
