JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Chevy Malibu ECU pin out?
I'm looking for a pin out for the ECU of a 1999 Malibu 4 cylinder. If you happen to have one and can pass it along that would be most excellent. Thanks.
Joanne: Engine Control Unit
Don r: I would love to but unfortunately the library is only open while I'm at work which is why I asked.
ZEDMILLY: I think I have a man-crush on you.
Pin
Wire Color
Circuit No.
Function
C1-01-C1-05
Not Used
C1-06
BLK
2759
Fuel Tank Pressure Sensor Ground
C1-07
BRN/WHT
633
CMP Sensor Signal
C1-08
PPL/WHT
430
CKP 7x Reference Signal
C1-09
Not Used
C1-10
GRY
2709
Fuel Tank Pressure Sensor 5 Volt Reference
C1-11-C1-17
Not Used
C1-18
BLK/WHT
451
PCM Ground
C1-19
PNK
639
Ignition Positive Voltage (2)
C1-20
ORN
480
Battery Positive Voltage (B+)
C1-21
DK BLU
417
TP Sensor Signal
C1-22-C1-24
Not Used
C1-25
ORN
406
Ignition Control Output 2-3
C1-26
WHT
423
Ignition Control Output 1-4
C1-27
TAN/BLK
231
Engine Oil Pressure Sensor Signal
C1-28
RED
1226
Transaxle Range C Input
C1-29
BLK/WHT
771
TR Switch Input A
C1-30-C1-31
Not Used
C1-32
GRY
1716
Knock Sensor (KS) Reference Low
C1-33
Not Used
C1-34
DK BLU
496
Knock Sensor (KS) Signal
C1-35
PPL
420
TCC Brake Switch Input
C1-36-C1-44
Not Used
C1-45
DK GRN
890
Fuel Tank Pressure Sensor Signal
C1-46
YEL/BLK
1227
TFT Sensor Signal
C1-47-C1-48
Not Used
C1-49
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
C1-50-C1-51
Not Used
C1-52
BLK
2751
A/C Refrigerant Pressure Sensor Ground
C1-53
GRY
23
Generator Terminal F Input
C1-54
YEL
410
ECT Sensor Signal
C1-55-C1-56
Not Used
C1-57
BLK
2752
TP Sensor Ground
C1-58
Not Used
C1-59
PPL
1807
Serial Data (Class II)
C1-60
BLK/WHT
451
PCM Ground
C1-61
PPL
1500
Ignition Positive Voltage (1)
C1-62
LT GRN
432
MAP Sensor Signal
C1-63
RED/BLK
1230
A/T ISS Sensor High
C1-64
YEL
400
VSS High
C1-65-C1-66
Not Used
C1-67
DK BLU
1225
Transaxle Range B Input
C1-68
PNK
1224
Transaxle Range A Input
C1-69
YEL
772
TR Switch Input B
C1-70-C1-71
Not Used
C1-72
GRY
773
TR Switch Input C
C1-73
WHT
776
TR Switch Input P
C1-74
RED
225
Generator Terminal L Output
C1-75
BLK
1744
Fuel Injector #1 Driver
C1-76
LT GRN/BLK
1745
Fuel Injector #2 Driver
C1-77-C1-80
Not Used
C2-01-C2-05
Not Used
C2-06
RED/BLK
1228
PC Solenoid High Control
C2-07
Not Used
C2-08
DK GRN/WHT
465
Fuel Pump Relay Control
C2-09
LT BLU/WHT
1229
PC Solenoid Low Control
C2-10
WHT
121
Tachometer Output
C2-11-C2-13
Not Used
C2-14
ORN/BLK
469
MAP Sensor Ground
C2-15
Not Used
C2-16
DK GRN/WHT
817
VSS Output
C2-17-C2-19
Not Used
C2-20
TAN
472
IAT Sensor Signal
C2-21
BLK/WHT
451
O2S 1 Low
C2-22
PPL
412
O2S 1 Signal
C2-23
TAN/WHT
1669
HO2S 2 Low
C2-24
PPL/WHT
1668
HO2S 2 Signal
C2-25-C2-26
Not Used
C2-27
BLK/WHT
2761
ECT Sensor Ground
C2-28
BLK
2760
IAT Sensor Ground
C2-29
WHT/BLK
2762
TFT Sensor Ground
C2-30
Not Used
C2-31
RED/BLK
453
ICM Reference Low
C2-32
Not Used
C2-33
GRY/BLK
2701
TP Sensor 5 Volt Reference
C2-34
GRY
2700
A/C Refrigerant Pressure Sensor 5 Volt Reference
C2-35
BRN
2704
MAP Sensor 5 Volt Reference
C2-36
RED
631
CMP Sensor Ignition Positive Voltage
C2-37-C2-44
Not Used
C2-45
DK GRN
83
Cruise Disable Output
C2-46
BRN/WHT
419
MIL Control
C2-47
Not Used
C2-48
LT BLU/BLK
396
Cruise Engaged Input
C2-49
YEL
657
TCC Release Switch Input
C2-50
Not Used
C2-51
YEL/BLK
1223
2-3 SS Valve Control
C2-52
Not Used
C2-53
LT GRN
1222
1-2 SS Valve Control
C2-54
DK GRN
335
LH Fan Control
C2-55
DK GRN/WHT
459
A/C Compressor Clutch Relay Control
C2-56
DK GRN/WHT
428
EVAP Canister Purge Valve Driver
C2-57
BRN
418
TCC PWM Solenoid Valve Control
C2-58
WHT
1310
EVAP Canister Vent Solenoid Driver
C2-59
DK BLU
473
RH Fan Control
C2-60
Not Used
C2-61
PPL
401
VSS Low
C2-62
DK BLU/WHT
1231
A/T ISS Sensor Low
C2-63
PNK/BLK
632
CMP Sensor Ground
C2-64
BLK/WHT
451
PCM Ground
C2-65-C2-70
Not Used
C2-71
LT BLU/WHT
1747
IAC Coil A High
C2-72
LT GRN/WHT
1749
IAC Coil B High
C2-73
LT GRN/BLK
444
IAC Coil B Low
C2-74
LT BLU/BLK
1748
IAC Coil A Low
C2-75
LT BLU/BLK
844
Fuel Injector #4 Driver
C2-76
PNK/BLK
1746
Fuel Injector #3 Driver
C2-77-C2-80
Not Used
Go to the library and look in Chiltons Auto Repair manual.
ECU?
aston martins emotional control unit??
