Chevy dying out
Earchie
Dashboard will flicker headlights will be dim and steering wheel will lock up.
What year?
Do you have a check engine light on?
Is the generator/charge light on or do you have a gauge with voltage readings?
If you have a check engine light you need to have it scanned.
What is the maintenance history of the vehicle, is it overdue for a tuneup?
Really hard to understand your abbreviated response.
Earchie
Message me I’ll send u the video 3254289104
Earchie
THERES NO CHECK ENGINE LIGHTS ON THE DASHBOARD WILL FLICKER STEERING WHELL LOCKS UP AND TRUCK DIES OUT. Chevy house already replaced red n black cable to the battery n it still does the same thing
Can you just answer the question
Did you go back to them and tell them the problem isnt resolved?
Your electrical system is dying do to a bad connection at battery or fuse box or ground.
Earchie
I told them that and they said it’s not that that it’s all good when they hook it up to a code machine
Take it to a different shop, you need someone to check all the connections starting at the battery.
