chevy 1994 silverado grounding issue?
jim
i have a 1994 chevy 6.5 diesel I t seems my gound on electrical system is faulty due to clicking when you start u can tap starter an fire right up
most generally car are in contact with the ground this is how they are designed. More info would be great if you want a real answer.
will you be insulated if hit by lightning? probably as long as you don't
touch any metal. therefore, the vehicle is grounded
check the one between the engine an the frame. should be braided steel flat.
