Can't see bulbs in dash any more--2003 Suburban
Suburbanized
A mile high
Hi
You can't see the bulbs that light the gear you are in on the cluster anymore. They are extremely dim. Is this something I can do? Is it relativity easy or no?
Zora?? :)
Also planning on replacing all of the bulbs in the radio assembly, since they're all going out, one by one, day by day. Thansk
It could be a defective dimmer switch or a loose ground wire.
Bump this thread...have the same issue and wondering what it could be. Removed the cluster and put it back in, lights got bright for a few minutes then went dim again. Ideas?
as was suggested did you eliminate a bad dimmer and a poor ground? do you have autolight feature and the dash sensor is defective?
It's not a defective dimmer switch because the rest of the dash/cluster is bright and happy. I'm guessing it's something internal with the board. Some resistors have failed or are failing and/or weak...probably will go with a rebuild.
