Can I remove my knock sensor on my 1994 Chevrolet Suburban? I think it...
burnsboy1
...effecting my Throttle Position Sensor.? My truck has a knock and I don't know if it is my TPS or my Oxygen sensor. But I have been told that my knock sensor may be effecting my throttle position sensor. I just want to know if I can eliminate my Knock sensor all together. My truck has a knock because of my crankshaft and that is where it is located.
you cannot eliminate the knock sensor it works with all the other sensors on the computer system,if its bad just replace it don't try to eliminate it, you,ll wind up with more problems than you already have on it,good luck.
