The headlamps come out with 2 pull pins on each lamp assembly. The lower unit for daytime lamps is held in place by a plastic snap clip (the clip is @ the far outside end. If you look real close you can see it, if cold use a screwdriver to snap out. NO WRENCHES are necessary for this application! Aside from the cold weather comment.
PS- An 03 may be the first year for the set-up I described, If that doesn't look like the way let me know I can tell you exactly how to do it!
the tail lites you gt from the trunk. theres a couple of wing nuts that hold in the tail lite assembly. you'll figure it out. careful you don't snap those cheap looking plastic clips.
alot of the rest you get from the ground,,,,literallly.
