Caliperplexed
rgpinder
Newbie here. Pulled my left front tire, removed the caliper pins and then tried to pull the caliper off. Used a pry bar. Still no go. I could tell it wanted to come but was catching somewhere. I concluded that it must be catching on a caliper piston, which means I need to know how to collapse the piston back into the caliper while the caliper is still on the rotor. What is the best way to do that?
It's probably the outer ridge left over on the rotor. You should be able to relieve pressure by opening the bleed screw ans the caliper will open
I said caliper, I meant rotor. As the pads wear the rotor down they leave a ridge on the outer edge.
SOLVED!
I ended up just buying a 6" c-clamp from Home Depot. Using that I was able to move the piston in enough to pull off the caliper. The piston was extended too far to prevent it from coming off. Thanks for the help.
