Battery stops charging. Restart and it charges
Jack_K
My 2007 Avalanche LT has an odd problem. I'll be driving and everything is fine. The voltmeter shows about 14 volts.
Then, all of a sudden, it feels like I just ran into a really strong headwind and the voltmeter drops to about 12 volts. If I continue driving it will eventually drain the battery and it won't be able to restart.
However, if when that happens, I put it in neutral, turn the ignition off, and then restart, the alternator starts charging again and the voltmeter shows over 14 volts.
I have a new battery (because of this I thought the battery was bad) and I'm now on my 3rd alternator. All 3 did the same thing. All 3 test OK because the alternator always works right after starting the engine.
I've learned that the computer can tell the alternator to stop charging (the alternator has wiring that connects to the computer). I suspect the problem is probably in the computer but I have no idea how to check it. I have no trouble codes.
Any ideas?
which computer has no trouble codes the ECM or the BCM? I would suspect it is BCM related and has to be scanned. I would also check the connections to the alternator for a broken wire in the insulation, with the engine running have someone watch the gauge as you pull on the wires. I just found a technical service bulletin on the NHTSA site which may apply to your problem.
Service Bulletin No.: PIT-4613A
Component(s): ELECTRICAL SYSTEM
NHTSA ID Number: 10026697
All Products Associated with this Service Bulletin
Details
0 Associated Documents
Manufacturer: General Motors LLC
SUMMARY:
GMC: INTERMITTENT NO CRANK AND/OR DISCHARGED BATTERY. COULD BE CAUSED BY A LOOSE CONNECTION AT THE 175 AMP MEGA FUSE LOCATED ON THE PASSENGER SIDE OF THE COWL. *PE
