Battery light
biggiebb
I have had my alternator and it's belt have been replace along with a new battery. the light on dash keeps coming on and the blower fan in side the car speeds up and down when the light comes on. I have been told to linw with it. Also I have the new alternator and battery checked alternator putting out over 14 volts and battery holding over 12 volts. I have checked all connections and all are tight. Please help
have you had the new battery load tested?
who tested the alternator a parts store like autozone or a dealer?
you need the battery load tested and you need a ASE certified mechanic to check the charging system who wont tell you live with it.
biggiebb
I have load test battery with a/c on and headlights at high beam and engine running voltage read 12.87 I will have charging system check
