Antifreeze leaking from 98 chevy malibu.?
phosl84
I have noticed there is antifreeze leaking on the right side of the engine (none leaking onto the floor though) . its been doin it for awhile now but got a lot worse lately. My car overheats like crazy after a couple minutes of driving and a lot of smoke comes out under the hood. What could be causing this??
Any help is appreciated,
THANKS in advance.
you have a leak so your low on coolant car over heats so eithe ryou got a bad hose or something easy and cheap to replace either way alot cheaper than a motor easy to open hood and look for wet spots where its wet will be where its leaking replace or tighten what it need and drive on dont fix leak car over heat one to many tiem blow head gasket and worse costing 1000's when a 15 dollar hose might have done it
