Ammeter 72 chevelle
tday815
I have a 1972 chevelle with gauge package. I replaced the printed circuit strip for the gauge cluster. I noticed before I changed the circuit strip that a ammeter gauge wasn't working and the circuit strip near the ampgauge was burnt indicating the reason for not working. I replaced the printed circuit strip everything worked great except for the amp gauge. It is working now but reads backwards. When I test it such as turning on the headlights when engine not running the gauge goes towards positive it should go to negative with current draw, not sure if I should swap the two amp meter wires I probably could find them and swap them. Any help would much be appreciated thank you
