chriswilhelmart
- Oct 12, 2013
- Age
- 37
This is a weird problem, So i have a 1999 vortec suburban, 5.7 350. Ran PERFECT for years and years, until the other day the lower intake gasket finally blew. So i looked up the procedure and being a somewhat experienced mechanic, i dug down and got in there, cleaned up the internal valley under the intake, and took my time! I had heard of some issues like not putting the dist. back in right, so i took extra precaution in every step. To my surprise, it started right up first turn, as if nothing had been done to is in the first place, after everything was fixed and put back together. But all of the sudden the idle started going up and down, to the point that when im in gear, and im stopped, it looks like i have hydraulics under the rig because of its violent thrust forward and back. once i get going down the road everything is fine. I had an emergency about 60 miles away and ive been driving and hauling a small trailer back and forth for about 2 days now. but this is getting dangerous at stops.
I finally tried something that i was "sure" wasnt going to work. I turn the truck on, pop the hood, and disconnect the mas sensor plug from the air intake tube, which immediately fixes the idle, then i replug it in a couple seconds later, and woila, problem is fixed. it idles smoothly, it drives great, (has TERRIBLE mileage) but everytime i turn the truck off and back on again, like to get gas, i have to repeat this mysterious series of steps to get it to idle for me.
Ive looked and looked, all the connectors are together, i used the same parts as before, other than the gaskets. I cant find any air leaks, etc. and i need this thing up and running correctly today! So if anyone can help, please get in touch!
Thanks,
Chris~
Thanks,
Chris~
