After disconnect the battery, the odometer and shifting not display. Cannot adjust the clock either.
Ion Fatol
To cleaned the terminals, 10 min and I reconnected it . After that, no display of odometer and shifting displays:pRND12
Was the key in the ignition while you were doing this?
You can try disconnecting both cables again and touch the two cable together briefly and then reconnecting the cables.
Otherwise you may have fried something when you reconnected.
