AFR v Trick Flow?
Kiwi HX
Hi,
I'm preparing to build a Gen 1 350 cid to go back into an old school Australian ute (the Aussie equivalent of an el camino)
Looking to generate about 400 hp at 5,500 rpm and 425 lb-ft.
TH350 with O/D unit, built for low end cruising, not looking to shred any tires or beat everyone out of the lights!
I think I have most of the parts list pretty well sorted out, but would like advice on AFR v Trick Flow heads and matching intake manifolds.
I'm really interested in everyone's thoughts and advice regarding:
AFR Eliminator 195cc CNC chamber and runners street head with 65 cc chamber matched with the AFR Eliminator Dual Plane 4150 manifold
v
Trick Flow Super 23 195, Fast As Cast, 64cc CNC chamber but not CNC runners matched with the Trick Flow Street Burner Dual Plane manifold
There's USD500 between them, AFR more expensive, but fully CNC heads.
Thanks very much.
James
How about an Edelbrock top end kit so cam, heads and intake are matched?
G
G-120922
Thanks for the message Zora,
I’ve certainly looked at a matching set from Edelbrock but couldn’t find just what I wanted. Great gear though.
I plan to match the heads & intake manifold. And match the cam & valve train from Comp so everything is working as well as they can.
Cheers
James
Just using Google AFR versus Trick Flow Small Block Chevy you will find information such as below
Kiwi HX
Thanks very much Zora...you're a better Googleer than me! This is exactly what I was trying to achieve.
Cheers
