kevinwillis
- Mar 22, 2015
- Age
- 62
I have a 2001 Suburban LS and the air conditioner works great for about 5-10 minutes and then stops blowing cold air, as if the compressor has stopped working. We turn the air off and open the windows and wait for about 30 minutes. Then the air will work again, but only for about 5-10 minutes.
I took it to our mechanic who said it has a damper problem that will run about $400, but that he could put in a heater bypass valve for $160 that would fix the problem. Well it didn't.
I researched a bit online and found this to be a common problem, but no real solutions. One person said they replaced the low pressure switch and that fixed the problem. I tried that, but the switch I got at the auto parts store was a different color, but he said it should be fine. We tried it, no luck. I n fact it was worse. I put the old switch back on, but now the AC blows warm air all the time.
This is very frustrating and I really need help!
