99 Suburban MAF low circuit voltage
turbinesurgeon
Ok. had some guy install a used engine in the 99 Suburban 5.7. I drove the donor truck 200 miles from where I bought it with no problems at all so I know the engine was good. I got the truck back from the installer and it showed codes for low circuit voltage and cam position sensor. Upon looking at cam sensor plug behing the distributor I found he had it wedged between the block and bellhousing. Plug has been replaced and plugged into the distributor and codes cleared. However after a few miles the check engine light comes back on. Is there a fuse for the cam position sensor that could have blown. Also changed out mass airflow sensor and it too is still coming up in the codes as not working
What are,the actual codes?
The cam sensor maybe bad
Did you install a new MAF sensor?
turbinesurgeon
codes are PO0340 and P0102. The truck has hesistation when you hit the gas from a stop and sporadic idle. ..some loss of overall power as well
