99 Suburban issues
NathanC
Having a few issues with my 99 K1500. When I bought it I drove 3 hours back home with zero issues. First issue I had after a few days of having it was the battery was draining while sitting. Battery has since been replaced and the issue still exists. Second issue is it cranks but doesn’t start. Cranks like a champ but doesn’t hit for some reason. I’m still learning about these beasts and would love some help. Thanks!
After you replaced the battery did the security light come on solid when trying to start?
Did you check the charging system before replacing the battery?
NathanC
Didn’t notice the security light. Will check that ASAP. Alternator did get replaced. Pulling correct power when I checked it with a multimeter
If you are sure the battery and alternator are good you need to use your multimeter to test for a parasitic drain.
Twin_Flyer
Did you check for spark? Do you hear the fuel pump for a few seconds when the key is first turned on?
Check for any blown fuses?
NathanC
Fuses are all good. Haven’t checked spark yet but changing plugs and wires next paycheck so I’ll check then. Did not notice fuel pump engaging, will be checking that soon as well
You never answered the question about the security light?
G
G-976737
Similar issue. Alternator was draining battery when vehicle off. Charge battery & unplug alternator, see if battery now holds charge.
NathanC
Just checked to see if there was a security light and it’s not on. I hear the fuel pump prime but I’m still going to check pressure and change the fuel filter as well
XL Overlander
New Mexico
Mine had a notorious crank but no start. It was the security system malfunctioning. Solutions: get a new key
Disconnect battery for ten minutes
word of advice.
If you decide to replace the fuel pump, only use AC delco.
tiktok4321
If it started and you were able to get it home, then I wonder why it would give you issues later. We have a similar issue with our '04, and it's definitely the fuel pump. But we've managed to always get it to start by the 2nd or 3rd crank. We crank for a quick second, listen for the fuel pump to stop (yes, even though it's bad, it still runs a spell), crank again, and voila.
