99 chevy malibu problems?
cali_life_style
I have several problems i would to get help on.
1st problem is that when i am driving uphill hill i seem to lose power the rpm's surge and the only to stop it is to accelerate i little more so that the passing gear kicks in but i dont have this problem on flat terrain.
2nd problem is i have a coolant leak coming from the passenger side coolant seems to be leaking from behind were the power steering pump pulley is i could be wrong.
3rd problem is my trunk dont stay open so i went a got a trunk tension rod from a junk yard to replace it and i cant seem to put it on the tension is when i twist the rod makes it difficult to hook on the bracket that it locks into is there a speacil tool to help with the installation of the tension rod or if some one has some advise on a easy to put on please help with any suggestions.
thanks in advance
