did a full tune up but theres no elecricity going to the wires. changed the coil pack and dist. cap. it cranks but wont start. fuel pump comes on and everything just no electricity going to the wires. could someone please help me out wih that?
did you check for spark to plugs with a spark tester?fuel pump coming on does not mean fuel pressure is good.....try spraying some starter fluid into intake and see if it trys to start or starts and stalls.if starter fluid does not work and no spark to plugs with a spark tester then may be a problem with crankshaft position sensor or ignition module.let me know results of tests.
