96 Silverado engine swap questions
Hebgbz702
My first brand-new car truck has been laid up for a while body interior is in good condition want to get it back on the road rebuilt 4L60E is on its way planning on doing an engine swap looking at a LS motor leaning on putting in a Corvette engine I know the wire harness ECU needs to be replaced is there anything that I'm overlooking I want something bigger than the 305 that's in there what LS motor matches up to my trans or is there anything that can just plug and play with balls👊🏼 . Swapping cause misfiring. History. White smoke intake manifold leak spiders replaced and gasket no smoke still missing once it hits operating temperature calling it a day and just wanted to do an engine swap 120k. Thanks for all your help
Look at the crate engines from www.summitracing.com and work with their technical line on compatibility with your vehicle and transmission.
