What did I do wrong? The morning after a big rainstorm I took my '95 burb to
the store and starting having weird issues with my brakes below 20mph. Even
though I wasn't getting a light on the dash I thought maybe a sensor or connector might have moisture in it interfering with the ABS system so I pulled the fuse and the brakes actually worked better but they still were not quite right. When I pulled the fuse the dash light illuminated. Turned out the inner passenger side brake pad broke and destroyed my rotor. I installed new rotors,
bearing hubs and loaded calipers. Tried to reset the ABS light with my scanner
and it was a no go even though I wasn't showing any codes-OBD-1 system. I went to plan B and did the jumper wire trick and the ABS light flashed a code 65 which is a bad control unit. Any ideas on how to reset the light? Thanks in advance for any help. Oh, BTW the 'burb
is a K2500.
is a K2500.
