sadan2drive
- Jan 10, 2010
replaced fuel pressure regulator, fuel pump, fuel filter and screen. cap, rotor, coil, tested ignition module.proior to to instaltion of the parts. truck ran fine untill gas was dumping in throttle body pump ran 5min after shut off..ran for few days after installing fuel pressure regulator. then truck shut down all together. started fixing testing parts and replacing them as told. while fixing truck alarm started making the flasher and lights blinck ever time i touched truck. button pad never worked on truck. so i dismantled alarm. truck will not start.................not to mention new rear brakes and axle seals......about to sell....help!!!!!!!!!!!!!!!!
