94 454 TBI burb idle problem
Tinney
suburban started stalling, ruff idle, replaced fuel pump, map sensor, tcs, 02 sensor, tbi gasket, no vacumn leaks...really lost and quite a novice, thanks in advance.
i'm sure you all will need more info. please ask questions and i will do the best to answer.
Do you have a check engine light on and if so did you have the code checked?
How many miles and have you ever removed and cleaned the throttle body? Why the new tbi gasket?
