krodriguez
- Sep 26, 2016
- Age
- 43
I have a 93 Suburban 4L60E transmission. Its giving me code 28 which say it is the Transmission gear pressure switch, signal-circuit malfunction. I also have code 43 which is the knock sensor code.
I have replaced the 1-2 Shift solenoid the 2-3 shift solenoid the TPS and the Pressure Control solenoid.
my truck goes fine and switches into 2nd gear and then hits 35-40 and will not go into 3rd gear.
I can manually do from 1st to 2nd and then when I go into D or OD the RPMs go redline.
I pulled up a diagram of what is under my transmission pan and it shows 2 TCC solenoids a 3-2 control solenoid and a Transmission Fluid Pressure Manual valve position switch.
Is the code 28 that transmission fluid pressure Manual valve position switch?
if not what else is there that I should look for?
