89 chevy truck 1500 silverado no power to fuel pump on?
Brian Reynolds
I have a 89 chevy truck with no power to fuel pump not even the two second start up. The fuel pump relay is good the pump is good. (I have no power to the fuel pump fuse, ever.) I only have one wire leading to the oil pressure switch. So not much to check there. as far as I can tell it doesn't have any kind of cut off switch. I'm starting to wonder if the ECM might have something to do with my problems. Can't figure this one out.
