74 nova license plate light assembly
chins74
I just purchased a 74 Nova SS and have been working on a few things. Can anyone tell me how many parts are part of the license plate light assembly? I have the metal housing,the plastic lens and the gasket. Is there a lens for the outside? Thanks for the help!
You state you have the plastic lens and then ask if there is a second lens? Can you clarify your question, how can there be two lenses?
Sorry for the confusion with the question! What makes up the license plate light for a 74 nova? I have the metal housing the plastic lens and the gasket. these 3 parts go inside the trunk and mount. Are these 3 things the whole assembly? I don't know if there is anything on the outside of the car besides the mounting screws? Thanks
When assembled does it appear that it will illuminate the plate area below, seems like you have everything based on your description.
You do have the socket and bulb?
Thank you for all your help! Yes I do have the socket and bulb. I didn't want to assemble and test it until I knew I had all the correct parts wich it sounds like I do. They were all laying in the trunk when I purchased the car. Thanks again
