On this engine there are two valve cover caps, one on the front driver's side and one on the front passenger side. Neither are marked Oil/add oil/oil viscosity as normally seen. Trying to determine which is used for adding the oil.
The passenger side cap is smaller and it appears to be a plug but driver's side cap has those little holes/screens on the underside of the rim and does not fit tight like the other cap.
And, is this really a 4-quart oil pan capacity engine?
Thanks.
Thanks.
