2019 Chevy Silverado 1500 Puts Towing Experience At Forefront
DETROIT — The all-new 2019 Silverado 1500 will introduce several levels of towing features to improve customers’ trailering experiences — all light-duty Silverado models have myChevrolet® trailering phone app capability and customers can add the Advanced Trailering System, which includes access to the system in-vehicle.
The Trailering Camera Package works in conjunction with both of these technologies and provides a more comprehensive trailer view.
Chevrolet is also helping to take the guesswork out of calculating the combined weight of customers’ truck and trailer combinations thanks to an industry-first trailering label.
In developing the all-new Silverado, Chevrolet spoke with 7,000 customers over the course of 18,000 hours. Sixty percent of those surveyed named towing as a key purchase consideration. Another recurring theme was the difficulty many customers have with certain aspects of trailering.
To address this, all four trailering levels offered on the 2019 Silverado 1500 will provide customers more confidence, easier trailer hitching and improved connectivity between the truck and trailer.
“Ultimately, these technologies serve to eliminate common pain points of towing and help provide customers with a less stressful experience while trailering,” said Tim Herrick, executive chief engineer, Full-Size Trucks, General Motors.
myChevrolet® app trailering features for smartphones
Included with the purchase of all 2019 Silverado 1500s, the myChevrolet® app will offer select trailering features such as pre-departure step-by-step towing checklists and a glossary of towing terms for compatible smart phones and data plans1.
The myChevrolet® phone app also allows drivers to conduct a trailer light test that uses an automatic exterior light sequence to help confirm that the trailer is properly connected. In the past, this was a two-person job – now a single individual can properly connect a trailer and check the lights.
The trailer light sequence can also be activated via the Advanced Trailering System.
For customers who tow more often, the Advanced Trailering System provides features to make towing a more seamless process. The system is standard on LTZ and High Country trim levels and available on LT, RST and Trail Boss trim levels. The system includes:
Auto Parking Brake Assist: Customers who’ve dealt with the frustration of perfectly aligning their truck and trailer hitch only to see the truck roll when they put it in park will appreciate this industry-first technology. It sets automatically when the vehicle is put into Hitch View to help avoid vehicle movement after the customer lines up the truck with the trailer and then shifts to park.
Hitch Guidance with Hitch View: This adds a dynamic backing guideline to the Rear Vision Camera system to help customers line up their hitch, adding some precision and a visual cue to reduce the difficulty of aligning a hitch to a trailer.
Trailer Tire Pressure Monitoring System: When properly equipped, this optional feature can monitor the tire pressure of the trailer tires using the truck’s infotainment system. This system also allows customers to monitor the temperature of their trailer tires to help prevent blowouts from overheating. Requires optional equipment and dealer installation.
Advanced Trailering System Infotainment app
This infotainment app that comes with the available Advanced Trailering System allows customers to track the mileage, fuel economy and transmission temperature of their truck while towing2. Customers can create and store up to five profiles, including guests, for different trailer types.
Brake gain memory is part of this system and works with the Integrated Trailer Brake Controller, which provides fingertip control of the trailer brakes, to let the customer set and save the controller’s brake gain setting for each trailer within their profile.
Another industry-first, Trailer Theft Alert, can activate the truck’s lights and horn if the harness of the trailer attached to the truck is disconnected3. Customers enrolled in the OnStar Safety & Security Plan will also receive a theft alert via their preferred method of contact: phone, text or email.
The available wireless trailer tire pressure and temperature monitors listed above are also integrated into this system. Four sensors come with the Advanced Trailering System, with more available as accessories. Dealer installation is required.
Trailer Camera Package
This all-new package enhances trailering views with three cameras that provide a 270-degree view:
Standard Rear Vision Camera.
Two side view cameras mounted in the side view mirrors.
An optional fourth accessory camera that mounts to the trailer provides an even more comprehensive view while towing.
Trailering label
Not all trucks, even from the same manufacturer, are exactly alike in terms of their capacities to tow and haul. Capability tends to vary widely from truck to truck and can be difficult to calculate.
To address this, Chevrolet has created an industry-first trailering label that is located on the driver’s side door jamb of all next-generation 2019 Silverado pickups. This label provides customers with the information they need to calculate their pickup’s exact capacities.
This label takes the guesswork out of towing and hauling and is tied to VINs of individual trucks, providing information such as:
Gross vehicle weight rating.
Gross combined weight rating.
Gross axle weight rating (rear).
Maximum payload.
Maximum tongue weight.
Curb weight.
The 2019 Chevrolet Silverado goes on sale in the fall of 2018.
1 Device data connection required. Available on select Apple and Android devices. Some features require connected vehicle services trial or active plan and working electrical system. Service availability, features and functionality vary by vehicle. See onstar.com for details and limitations.
2 App functionality and features vary with vehicle equipment and trim level. Device data connection may be required. Available on select Apple and Android devices. Some features require connected vehicle services trial or active plan and working electrical system.
3 OnStar Safety & Security Plan, working electrical system, cell service, GPS signal, and armed GM factory-installed theft-deterrent system required. Requires contact method on file and enrollment to receive alerts. Message and data rates may apply. Service availability, features and functionality vary by vehicle. OnStar links to emergency services. See onstar.com for details and limitations.
