2018 Chevrolet Tahoe RST
RST SPECIAL EDITION BRINGS STREET LOOK AND POWER TO THE NEW CHEVROLET TAHOE AND SUBURBAN
Tahoe RST available with 6.2L V-8, 10-speed automatic transmission and Magnetic Ride Control
Today, Chevy introduced a new special edition for the Tahoe and Suburban: the street-performance Rally Sport Truck, or RST. The Tahoe RST will also be available with a new Performance Package that includes a 420-hp, 6.2L V-8 engine; Magnetic Ride Control with performance calibration; and an all-new Hydra-Matic 10L80 10-speed automatic transmission.
“Chevrolet has continually invested in Tahoe and Suburban, developing models with varying combinations of capability, technology and performance to meet the needs of different customers,” said Sandor Piszar, Chevrolet Truck Marketing director. “The RST is designed for customers who want a street performance look without sacrificing capability or refinement, along with the option of increased performance as well.”
RST will be available on Tahoe and Suburban models in the fall of 2017. Inspired by aftermarket trends, virtually all chrome trim has been eliminated for a street performance appearance. Changes include body-color grille surround and door handles; gloss-black grille and mirror caps; black roof rails, window trim, badging and Chevy bowties. RST also includes exclusive 22-inch wheels wrapped in Bridgestone P285/45R 22 tires.
Available upgrades for Tahoe and Suburban RST include a Borla performance exhaust system that offers a 28 percent improvement in exhaust flow, for a 7-10-horsepower gain at the rear wheels. An available brake package features massive front red Brembo six-piston, fixed aluminum calipers with brake pads clamping on larger-than-stock 410 x 32mm (16.1 inch x 1.3 inch) Duralife rotors coupled with a 84 percent increase in brake pad area and a 42 percent increase in rotor area to increase system thermal capacity. Duralife™ rotors feature a hardened surface to reduce corrosion and provide quieter braking with less vibration.
The Tahoe RST will also be offered with an exclusive Performance Package that includes Magnetic Ride Control with performance calibration, 6.2L V-8 and the new 10L80 10-speed automatic transmission.
This is the first time Tahoe will offer the 6.2L V-8, which delivers an estimated 420 horsepower and 460 lb-ft of torque. The engine features three state-of-the-art technologies — direct injection, Active Fuel Management and continuously variable valve timing — to make the most of power, torque and efficiency across a broad range of operating conditions.
The 6.2L V-8 will be paired with an all-new 10-speed automatic transmission. With smaller steps between each ratio, the transmission maximizes engine power under acceleration. With a wide 7.39 overall gear ratio spread and lower numerical top gear ratio, the transmission also improves efficiency by reducing engine revolutions at highway speeds.
Based on preliminary estimates, the Tahoe RST Performance Package will offer a towing capacity of 8,400 pounds and the truck will be cable of 0-60 mph acceleration in less than 6 seconds. Full performance metrics will be announced closer to launch.
Magnetic Ride Control is an active suspension that “reads” the road every millisecond, triggering damping changes in the electronically controlled shock absorbers in as few as 5 milliseconds. As a result, the suspension delivers both improved body-motion control during cornering and a more comfortable ride while cruising. The new performance calibration included in the Tahoe RST Performance Package increases body control for even higher levels of responsiveness and comfort.
“When you want to hustle, it is incredibly fast, with significantly higher levels of acceleration, braking and road-holding grip,” said Eric Stanczak, chief engineer for Chevrolet full-size trucks. “When you want to relax, it is very refined, with exceptional ride comfort and interior quietness.”
