2016 Chevy Camaro Specifications
2016 Chevy Camaro Overview
Body style / driveline: four-passenger, front-engine, rear-drive coupe
Construction: unitized body frame, one- and two-sided galvanized steel
EPA vehicle class: coupe
Manufacturing location: Lansing, Mich.
Engines
2.0L Turbocharged I-4 VVT DI 3.6L V-6 VVT DI 6.2L V-8 VVT DI
Displacement (cu in / cc): 122 / 1998 222 / 3640 376 / 6162
Bore & stroke (in / mm): 3.39 x 3.39 / 86 x 86 3.74 x 3.37 / 95 x 85.6 4.06 x 3.62 / 103.25 x 92
Block material: cast aluminum w/ cast-in-place iron bore liners cast aluminum w/ cast-in-place iron bore liners cast aluminum w/ cast-in-place iron bore liners
Cylinder head material: cast aluminum cast aluminum cast aluminum
Valvetrain: DOHC, four valves per cylinder, continuously variable valve timing DOHC, four valves per cylinder, continuously variable valve timing; Active Fuel Management overhead valve; two valves per cylinder; Active Fuel Management
Fuel delivery: direct high-pressure fuel injection direct high-pressure fuel injection direct high-pressure fuel injection
Compression ratio: 9.5:1 11.5:1 11.5:1
Horsepower (hp / kW @ rpm): 275 / 205 @ 5600* 335 / 250 @ 6800* 455 / 339 @ 6000*
Torque (lb-ft / Nm @ rpm): 295 / 400 @ 3000-4500* 284 / 385 @ 5300* 455 / 617 @ 4400*
*SAE certified.
Read more...
