No, older vehicles used a group of resistors to control speed. Modern vehicles use an electronic module.By control module does that mean the selector switch for the blower
Where can I find the control module,and can it be tested to see if it's working?No, older vehicles used a group of resistors to control speed. Modern vehicles use an electronic module.
I mentioned the scan tool which would be a private shop or dealer. If the problem isn't present it may not show any codes.Where can I find the control module,and can it be tested to see if it's working?
You would have to research thatThat's what I'm afraid of. I may invest in a scanner and check it out my self. Is there a certain type of scanner to check for that problem?
