Hi Folks,
My liftgate will not open. When I press the interior roof liftgate switch or the key fob button, I get a single flash of the brake lights and I hear a click in the fuse box in the engine compartment. I've checked the 15 amp fuse and it's fine. The only thing I can think of is that we went camping and left our liftgate open for a while. It ended up closing on it's own and then we could no longer open it.
The manual says the following: "If the liftgate is opened using power operation and the liftgate supports struts have lost pressure, the turn signals flash and a chime will sound. The liftgate stays open temporaritly, and then slowly closes. See dealer for service before using the liftgate."
I'm willing to bet the struts just need replace, but I cannot even get the liftgate open, even after turning off the automatic liftgate feature with the interior button. Is it possible to liftgate relay has failed and will not allow the actuator to open the latch even in manual mode?
I'm at a loss and could use an assist. Thoughts?
