2010 impala ltz 3.9 v6 wheel hub
G
G-30812
We have a 2010 impala ltz 3.9 v6. Trying to reace the wheel hub. Ordered 3 different onez from 3 different places. They have all come with a type wire with a plug on the end of the wire, as if its for a sensor. Ours does NOT have that wire on it. The abs sensors are plugged in differently on ours. I cannot find a hub anywhere WITHOUT the wire attached to it. Could not find any numbers on it to find the correct one. Please someone help!
Front or back?
Rears are 13585741
Front 19259596
I have actually done alignments in shops using alignment racks. I also read the link you attached.
Unless your rims are not properly seating on the wheel hub or something is bent in your suspension there is no way a rim will effect camber.
Did you look look at the hub numbers above?
