2010 cooling fan intermittent issue
Fumblefingas
Lost vegas
This has been going on a couple years just off and on.
I'll notice sometimes the coolants temp has risen but the fan doesn't kick on. So i turn on the AC, fan comes on, cools down and good to go. Happens off and on, figure it must be a sensor or relay but uneducated guess. I'm in Las Vegas and want to finally fix the issue before summer. Any tips appreciated. The dash gauge reads fine showing temps.
Do you have actual temperature readings using an IR gun or scan tool or the gauge?
Without those numbers it's just guessing.
You say the temperature has risen but without knowing it has risen to the 215 to 225 range no way of knowing if you have a real problem.
Fumblefingas
Lost vegas
No. I can smell it though and check the gauge. I've had it since 2012. Does it have 2 fans or 1 two speed fan? Thanks
