hillclimber
- Mar 30, 2014
Problem with coolant temp gauge and air conditioner at the same time. Whenever temp gauge stays on 100, the ac doesn't work. Sometimes the gauge reads correctly, ac works fine. Went to Auto Zone, had it plugged up, code says coolant temp sensor bad. I replaced it with a new one, my goodness what a bad job. The 08 model's is on the right side of the head directly behind the exhaust manifold under the firewall. Couldn't buy a socket to fit this sensor, had to make one. Anyway, I got it changed. NO, it was not behind the alternator. That is true for other year models. The rest of the story is that nothing has changed. Still have the same problem. Obviously there is another issue I need to fix. Anyone else ever dealt with this before? Any help will be greatly appreciated.
Thanks
Thanks
