2008 Surban LT
MHarrell
Hello,
I have a issue with my fog lights, I have searched for a wiring diagram to no avail, the fog lights do not turn on by the button on the light switch, i have 12 volts at the relay and the terminal for the fog lights, if i bypass and take the negative side of relay to ground the relay does operate and the fog lights do turn on.any suggestion's or ideas would be appreciated.
bad switch, is it a switch you can jump to see if that is where the problem lies
this is the type of head light switch i have
you would need to remove the switch and determine which wires are for the fog light
