I have a 2008 Silverado 4x4 with stock 17 rims I want to swap when a set of denali wheels I found 20s my question is will they work and will my old lug nuts work?
the wheels are the same pattern 6-139, the offset and back spacing are the same. So in theory they should fit. You will have to see if the lugs fit, cannt tell without seeing the wheel.
beyound the mechanicals of drive shafts, transfer case, etc....you will also have wiring, electronics maybe ECM changes. And what about stabilitrack? Sounds lot a lot to figure out. I also vote for a new truck.
