2005 Fuse or Circuit Breaker for Door and Cluster
Coach Jonno
Needed to jump my 2005 Avalanche and used one of those portable USB battery chargers with jumper cables. I think I may have shorted a breaker or fuse. Both front doors no longer have power and gauge cluster also not working. Truck will start and rear doors ok. Any thoughts on which fuse(s) and/circuit breaker to replace? I looked at the diagrams but have yet to find the correct fuse if there is one.
Coach Jonno
Did you look in the owners manual?
I have the diagrams for the two fuse box areas (section 5 of the manual around pages 105-115). It is not clear from them which is specific to this. I could go around swapping a bunch, but was hoping someone had experience in this area.
Why would you have to swap, the broken metal strip should be visible if the fuse blew.
Page 107 lists a Drivers Door Harness Connection.
Page 111 lists an LBEC fuse.
Page 112 lists the instrument panel.
