2003 suburban possessed ????
Oncea3fan
this thing is driving me crazy.
started off the altinator went out saturday night, the warning light never came on til the battery was near dead .
the next day I recharged the battey and bought a new, not rebuilt altinator.
everything seemed good and I cleared the codes with my code reader.
test drove and all was good.
monday morning I start the truck up and have no gauges, at work I remove battery terms while running to see if alt is charging, seems ok. , fuses are good . at the end of the day I start it up to warm up . the engine revs to like 1500 rpm for a 30 second period.
go to leave about 20 min. later and the gauges start working again , but with in 100 feet I lost my breaks( made a sound like the anti lock breaks were working) then the truck stalls.
refire it rev a little seems fine but gauges are all over the place and the heat is switching from heat to defrost and back by it self. I go in to the store and come back out go to start it , and it seems the battery is dead, it bearly turns over. but on a 2nd 30 seconds later it spins over fine and starts up.
runs and little ruff and the gauges are fine but no dash lights.
I checked for bad connection s and good grounds all looks good.
this morning all is back to normal, but driving to work the heater fan revs up and down on its own , driver seat heater act crazy on off on off. and the head light dim and bright and dim and bright.
whats going on .....any clues
thanks!
Will
wow it does sound possessed lol sorry, it has to be a bad ground somewhere, this style burban is notorious for strange electrical problems that the dealers can never trace out. it usually always comes down to a bad ground. good luck and post the answer pls
