I recently changed the motor in my girlfirends car( 2003 chevy malibu, 3.1 engine) and now in the mornings or after the car has set for a while, it does want to start... It just will set there a crank like it wants to start. If you wait for the fuel pump to stop running then it will start right up however sometimes you have to turn the key off and on several times to get the pump to kick on. A local garage says that is an electrical problem but they arent sure what it is and have went through it several times. Also every now and then the radio, AC and dash will go out even when I do get it to run.
Recently had the battery, starter and alternator test. They are good. the fuel pump and filter have been changed. Any ideas why the fuel pump only kicks on every now and then? I know this is my starting problem. This car is confusing me!!!
