2003 Chevrolet Silverado brake lights dont work. Changed bulbs, top cab light comes on when depress the pedal?
however, the rear lights dont come on. When I put on the hazards, they flash, (the middle ones) The top ones come on when I remotely lock/unlock doors. I checked the fuse block under BRAKE 10 amp, both in the cab and under the hood, both fuses are good. so if all the bulbs are good, the pedal makes the top cab light go off, all lamps in the housing do in fact work and are good, the fuses are good, what else could it be? is there another fuse I missed under a diff name? is it the computer.....I'm lost!!!!!
