2002 Suburban running rough
lrodptl
Any ideas? Thanks.
2002 K1500 Chevy Suburban, 5.3 Liter Flex Fuel, 193,500 miles, just replaced
plugs and wires.
Cold start, runs rough, tripped codes P0171 (2 - one for bank 1, one for sensor
Bank A) and P0174 (also 2 - one or bank 2, one for sensor bank B). Runs great
once fully warmed up.
Intake manifold pressure bounces round 11- 12 and goes to 10 steady once warmed
up
Before the plugs/wires. Intermittent in the cold. Warm weather, the problems go away.
I cleaned the MAF and the problem went away for a while but the weather also got warmer. I could replace the MAF.
look first at the suggestions concerning vacuum leak
Check your coolant temperature sensor and make sure it's up to snuff on the resistance readings.
