I know this question has gone through before, But...
My 2001 Silverado, after sitting for more than an hour or so, requires TWO (sometimes three) cranks before it will start. I crank it, it turns over fine and strong but won't start. I let go, and immediately crank it again and it almost always starts right up, just fine, second time. Sometimes third, and getting more frequently on the third.
I replaced the fuel pump already, but that was about 100,000 miles ago. That time, it was just DRT (Dead Right There). This time, it's persnickety as described above.
My thought is that if it were the fuel pump, there would be fuel feed problems while running too. But there aren't. it runs just fine and strong once started and running.
But... it has also, at the same time, developed a tendancy to die after starting. Start it, put it in reverse, and it sometimes sputters out.
But once running at speed, it's fine and strong. I'm wondering about fuel FILTER. Could sediment in the fuel filter be giving it a hard time at the low pressure start and then runs fine once the system is up to pressure? Is it possible that a simple fuel filter may fix?
Plugs and wires? Please, anything but the friggin' $500 fuel pump job! ;-)
Thanks!
kirbylw
Thanks!
kirbylw
