The truck is a 1500 1/2 ton 2WD the rear brakes need to be replaced How do i do this and is it easy I know a little about cars just have never worked on brakes before.
for a diy its pretty easy. Well it is rear disc right? take off tires, take off top and bottom bolt that mounts to bracket, (if changing rotors take both mounting bolt off, keep inside pad in and compress caliper w/ channel locks or something like it.. the rest is in reverse order. if its drum well that a little bit harder... TAKE ONE SIDE APART AT A TIME!! TAKE YOUR TIME
