G
G-901443
I have a 2000 suburban 1500 4x4 and needing to put a new engine in it. My question is, if I stick with the ‘00-‘03 range it should have the manual throttle body correct?
Also, if I find an engine that came out of a 2wd will it fit fine or will more parts need to be swapped out? Do I also have to carry the ECM from the donor engine to the suburban and take off the old ECM?
Thank you
Thank you
